Troubleshooting Sunroof electrical
Old Mar 25, 2014 | 03:54 PM
joyntanovich's Avatar
Default Troubleshooting Sunroof electrical
Hello!
My sunroofs stopped working all of a sudden (like many others)...
I replaced the ECU. the fuse is good. I have a test light (vs. a voltmeter) and am trying to figure out where the breakdown could be?
I've tried plugging my test light into the badk of both plugs (for front switches) and there is NO power at any of these points. (I replaced the ECU with another new tested one).
If it's not the ECU, or the fuse, and there's no power at the motors, what else could it be?
Thanks for any input....
Old Mar 25, 2014 | 08:31 PM
Download shop manual called the RAVE and it has electrical diagrams. Use a meter. Cheap at Harbor Freight, etc. Many voltages are found between a particular terminal and frame ground. Using the truck for the return side saves half of the wiring.
DiscoIIBrandon
Jul 13, 2011 09:25 PM
BigRed98
Jun 21, 2010 12:30 AM
lipadj46
Dec 15, 2009 07:52 PM
fireball168
Nov 11, 2007 03:12 PM
