Truck Starts and Shift gears but WONT MOVE!!
Old Feb 24, 2016 | 09:06 PM
Caliman04's Avatar
4th Gear
Default Truck Starts and Shift gears but WONT MOVE!!
Hello Guys , i have an 2003 Discovery II . The Truck was running Fine ,all of sudden stop moving , i press the gas and truck wont move . It takes all Gears perfectly ,just would not Move .
Please need some Help
Old Feb 24, 2016 | 09:10 PM
Alex_M's Avatar
First, any engine codes?
Second, are you sure it's actually changing gears? Could it be the selector is just moving?
Third, is it moving literally none at all, or is it trying to move even a little?
Old Feb 24, 2016 | 09:50 PM
number9's Avatar
Did you check to see if transfer box out of neutral?
Old Feb 24, 2016 | 09:51 PM
LR03NJ's Avatar
Are you still stuck? Seems like your first post in the forum. Just keep posting and surely someone will be able to assist you. I got stuck once too and someone helped me here. Good luck!
Old Feb 24, 2016 | 11:47 PM
Caliman04's Avatar
4th Gear
A code came up for Outer shaft speed sensor , i shift gears goes threw every gear just doesnt move . My friend try to do an data and it shows when gears change , when they go to the converter the converter does not show any pressure
Caliman04's Avatar
4th Gear
Transfer Box not on Neutral 😔
Old Feb 24, 2016 | 11:48 PM
Caliman04's Avatar
4th Gear
Thank You , you guys here are great responding back amd giving nice details i really appreciate it
Old Feb 25, 2016 | 08:04 AM
Alex_M's Avatar
Has your transmission been shifting funny or acting weird in any way for the last while? Maybe an odd noise or shifting really slow?
Old Feb 25, 2016 | 08:16 AM
drowssap's Avatar
when was the last time you checked the fluid and filter?
is the xyz switch moving when you change gears?
Old Feb 25, 2016 | 09:43 AM
batard's Avatar
Is this a manual or automatic? If an automatic, it seems odd that it would shift gears if it's getting an input of zero from the wheel speed sensors.
Obviously you inspected the front and rear driveshafts and they're fine.
