Trying again......#6 and #8 not firing
Im getting P0306, P0300, P0301, P0306, P1300. New coil pack, New Champion plugs. New Magnecor ignition wires. New block. New 02 sensors. I did a spark test on the plugs that correspond to the cylinders getting the misfire (1, 6) and found that 6 was getting a very small spark while 1 was getting a very good spark. I swapped them around to see if anything would change and found that 6 is still getting a small spark regardless of a different plug. Yet Im still getting cylinder 1 and cylinder 6 misfire codes.
