Trying again......#6 and #8 not firing
Old Apr 23, 2016 | 03:14 PM
lr3_ovrlnd3r's Avatar
Default Trying again......#6 and #8 not firing
Codes P1300, P0306, P0308
Not getting fire to the spark plugs. Wires changed, plugs changed. I have what appears as 1 coil from each coil pack not firing (top center). Any ideas? Plugs are good, swapped to other cylinders and getting spark.
Old Apr 23, 2016 | 06:33 PM
shanechevelle's Avatar
I am having the same issue, just with different cylinders.
Same 1300 code.
My CEL is flashing at me now too.
Going to take it apart tomorrow
Old Apr 23, 2016 | 08:37 PM
TRIARII's Avatar
Im getting P0306, P0300, P0301, P0306, P1300. New coil pack, New Champion plugs. New Magnecor ignition wires. New block. New 02 sensors. I did a spark test on the plugs that correspond to the cylinders getting the misfire (1, 6) and found that 6 was getting a very small spark while 1 was getting a very good spark. I swapped them around to see if anything would change and found that 6 is still getting a small spark regardless of a different plug. Yet Im still getting cylinder 1 and cylinder 6 misfire codes.
Old Apr 23, 2016 | 10:48 PM
cappedup's Avatar
Swapped the coils? As horrible a job as it is. I know you have a new one, but it's the only way to be sure (apart from nuking it from orbit.) 1+6 same coil etc.
Defo got great connections at the coil?
Did you drop a bolt in the intake by chance? The new cause of misfires.......
Old Apr 23, 2016 | 10:53 PM
Charlie_V's Avatar
Hahaha. Funny!
slimtexas1
Oct 13, 2015 10:54 PM
m.qualls89
May 16, 2013 09:21 PM
llcookej
Apr 6, 2013 08:35 PM
Aff2010
Apr 16, 2011 08:03 PM
lennie5936
May 7, 2008 12:00 AM
