Tune Up
Old Jan 14, 2017 | 05:13 PM
LR03NJ's Avatar
Originally Posted by OffroadFrance
The 'Italian tune up' is you give the truck or car a 'b@lls out' hard run using max throttle for 15 to 30 minutes and then see whether it's improved, as already said, it's a make or break scenario.
Very true. I do that every time. Even clears pesky misfire codes. Rovers take time to adjust new stuff put in them.
Old Jan 15, 2017 | 03:07 PM
AZRover's Avatar
Originally Posted by mln01
These guys are jerking you around.
Starting with plugs, wires and an air filter is just fine. But even before that, are there symptoms or codes you are intending to address with a tuneup?
Thanks mln,
No codes or symptoms of problems that I need to address. Truck had 130k on it when I bought it in Dec 2009. Truck now has 188k on it and I had never changed the plugs or wires out since I've owned it. It's just running a little sluggish currently.....nothing major. I should also mention that I will also give it an oil and filter change.
paul7829
Aug 15, 2006 01:08 PM
paul7829
Aug 15, 2006 12:00 AM
anthonyb
Jul 24, 2006 01:21 PM
disco12
Dec 20, 2005 06:43 AM
winnegar
Sep 27, 2005 12:51 AM
