Two codes
![Cool](https://landroverforums.com/forum/images/icons/icon6.gif)
Hey gang, after changing my starter, finally figuring out my parking light situation, and replacing numerous fluids...etc... After a 2,500 mile trip to az. From pa. I have one last dilemma for now..........check engine......light......the dreaded warning beacon from you knw where!!!!!!!!!! Two codes p0138 o2 sensor, and p1193 not sure about the second one. Anyway is b1-s2 under the driverside, downstream? And is p1193 the probable cause of the bad o2 sensor?
Disco...................spike....................a nybody.............................?
Peace and fight the nwo
Here is a link to codes http://www.troublecodes.net/landrvr/
They show the following:
DIAGNOSTIC TROUBLE CODES
*Codes* are used to identify the 4 Oxygen Sensors.
A = Bank A of the engine. Cylinder #1 is located on Engine Bank A.
B = Bank B of the engine.
U = Upstream of the Catalytic Converter.
D = Downstream of the Catalytic Converter.
Example:
A D = Oxygen Sensor Engine Bank A, Downstream of Catalytic Converter.
Example:
Scout_Beagle
09-24-2010 08:58 PM
