Two codes
Old Feb 20, 2009 | 10:42 AM
FALLFORWARD's Avatar
Cool Two codes
Hey gang, after changing my starter, finally figuring out my parking light situation, and replacing numerous fluids...etc... After a 2,500 mile trip to az. From pa. I have one last dilemma for now..........check engine......light......the dreaded warning beacon from you knw where!!!!!!!!!! Two codes p0138 o2 sensor, and p1193 not sure about the second one. Anyway is b1-s2 under the driverside, downstream? And is p1193 the probable cause of the bad o2 sensor?
Disco...................spike....................a nybody.............................?
Peace and fight the nwo
Old Feb 20, 2009 | 01:20 PM
grussell's Avatar
Here is a link to codes http://www.troublecodes.net/landrvr/
They show the following:
DIAGNOSTIC TROUBLE CODES
*Codes* are used to identify the 4 Oxygen Sensors.
A = Bank A of the engine. Cylinder #1 is located on Engine Bank A.
B = Bank B of the engine.
U = Upstream of the Catalytic Converter.
D = Downstream of the Catalytic Converter.
Example:
A D = Oxygen Sensor Engine Bank A, Downstream of Catalytic Converter.
Old Feb 20, 2009 | 01:27 PM
1193 is a Heater circuit open downstream
138 is an 02 sensor circuit high voltage bank 1 sensor 2
How many miles on your truck and what year is it?
Old Feb 20, 2009 | 01:48 PM
97' sd7 144,000
Old Feb 20, 2009 | 01:53 PM
Sounds like it is time for all 4 02's to be repalced.
Atlantic British has them on sale.
Old Feb 20, 2009 | 07:39 PM
Make sure that you replace the O2's in pairs, sets are better but pairs are ok.
When was the last time it had a tune up?
When you are in need of a tune up the truck will throw O2 codes, and then mis fire codes if left to go for to long.
Old Dec 10, 2009 | 06:39 PM
robot808's Avatar
Digging up a thread...
o2 sensors should be replaced in pairs... so both on one bank at a time?
Thanks,
rmace1
Jun 8, 2012 08:37 AM
cobbcj7
Mar 14, 2012 04:12 PM
Discolife
Nov 14, 2011 09:27 PM
DiscoIIBrandon
Nov 17, 2010 09:23 AM
Scout_Beagle
Sep 24, 2010 08:58 PM
