Two questions, one of them is probably stupid...
Old Mar 2, 2009 | 11:34 PM
tornado_735's Avatar
Default Two questions, one of them is probably stupid...
I have the flashing off road light, which means the rear is either rising or returning to stock height, and then I have the self-leveling suspension light illuminated, meaning there is a fault with the system. Like I said before, I know the tranny and driveshaft are the major problems I'm facing right now, but I'm just trying to get the little crap fixed and out of the way before I have the money to get the major crap fixed. Now, the question is, where is the air pump located? I would like to check it out, see what it looks like, what condition it's in, check the filter, etc. but I don't know where it is. Second, why would the offroad light be flashing if the suspension light is on?
And the stupid question is this...every time I turn the key on, I hear what sounds like a little fan that comes on in the dashboard, even though the blower motor is off. What the hell is it? I thought it might be a temp sensor for the Automatic Climate control, but I could be wrong. I often am.
Old Mar 3, 2009 | 08:54 AM
nynole's Avatar
The best thing to do is to get a copy of Rave, which is a pdf copy of the service manual. Some have indicated that it is a free download somewhere, I bought the CD on Ebay for $5. Its almost a necessity for the DIY'er. The noise you hear that sounds like a vacume in your dash is the Secondary Air Injection, its an emissions thing. Do a search on this forum for more info
Old Mar 3, 2009 | 09:30 AM
okdiscoguy's Avatar
Might need to make a trip to the dealer to have your SLS reset. Grab a copy of the RAVE manual and go through it. Not sure off hand where the pump is. DiscoMike might have some suggestions on the suspension.....
These trucks have a proprietary language for the computers, so you have to get someone with a rover compatible scanner to set things and read codes other than OBDII that set off your CEL. Brakes and suspension are a dealer or indy shop item...
Old Mar 3, 2009 | 11:34 AM
CCROVERSE01's Avatar
It is located on the drivers side. On the frame between the front and rear doors. Has a cover that can be removed to inspect. You should be able to see the hose lines coming out the back running to the SLS.
Old Mar 3, 2009 | 12:16 PM
malmberg's Avatar
CCROVER is right about the compressor. The noise that you hear when you turn on the key is a fan in the dash. If you look to the left of the steering wheel you will see a few slits where it sucks the air in. If you take compressed air and blow it out the noise should go away. If it is real dirty remove the panel under the dash by the fuses and clean it out.
Old Mar 3, 2009 | 12:26 PM
Yeah, I saw the little vent. I'll clean her out. What is it for? Someone mentioned Secondary Air Injection, but according to my VIN, I don't have it. What is that anyway?
Old Mar 3, 2009 | 12:27 PM
discoxd's Avatar
http://www.green-oval.com/joomla/ind...d=13&Itemid=29 rave download
Old Mar 3, 2009 | 02:34 PM
That little fan is a cooling fan for the electrics behind the dash, just like on your computer.
greenharoguy
Feb 19, 2013 08:52 PM
bcbp
Jun 3, 2012 12:39 AM
collin Barrows
Off Topic
Jul 30, 2011 07:09 AM
humroot
Mar 12, 2010 06:31 PM
discobob
Dec 26, 2008 07:55 AM
