type of oil
Old May 17, 2007 | 10:34 AM
hendoc3's Avatar
Default RE: type of oil
So the Land Rover dealer where I live uses Penzoil nonsynthetic 5w/30. Why do people always want you to go to the dealership to get your oil changed when they use Penzoil, which from what I hear is not good for Land Rovers? Why doesnt the dealership use synthetic oils?
Old May 17, 2007 | 10:50 AM
Old School's Avatar
This is great, thanks. Being that I have never changed my own oil, this will be fun to learn. I usually go to Wally World, pay them the $15 and let them do it. I will give this a try for sure.
Thanks!
Old May 17, 2007 | 10:57 AM
hendoc3's Avatar
never go to Wal-Mart. My dad took his truck there, went and picked it up, drove it home, checked the oil, and there was nothing on the dipstick.
Old May 17, 2007 | 11:18 AM
Old School's Avatar
Having been going to Wal-Mart for over four years, I have never had a problem. Used to go to a "quick lube" joint. They charged twice the amount for the same service and products. I will look into changing my own oil. I am sure it is simple to do if I can get to the filter.
Old May 17, 2007 | 12:44 PM
RedElephant's Avatar
What I did is let someone else do it, but I brought my own oil (Mobil 1 synthetic that I bought actually from Wal-Mart). That's a lazy option, but at least you know what you are getting poured into your engine. And it's probably a very little bit cheaper compared to asking them to use the synthetic (if they give you this option at all).
A question that I have is: you are supposed to replace the copper washer on the drain plug. Where do you people get that little thing from?
Old May 17, 2007 | 03:13 PM
hendoc3's Avatar
So the service tech. at the Land Rover dealership where I live said that he doesnt recommend synthetic oils and that switching to a snythetic causes more oil leaks.
Old May 17, 2007 | 03:44 PM
okdiscoguy's Avatar
that was true in the 70's. Not today. Synthetics might leak a little when you first put them in, but they re-condition all of the seals. If there are deposits clogging a leak, they will clean them out, but then polish the mating surfaces. I say BS. Use synthetics.
Old May 18, 2007 | 04:48 PM
ArizonaDiscovery's Avatar
Agreed times 3 with okdiscoguy. All oils are compatible today, what the mech told you was indeed from the 70's. THEY WILL NOT CAUSE IT TO LEAK! period dot.....
Old May 19, 2007 | 07:34 AM
Aquaholic's Avatar
The dealership here in Austin uses Castrol Syntec (a blend).
Old May 19, 2007 | 10:10 AM
dc10freighter's Avatar
Another problem with the quick lube guys, and Wal Mart is the filters. Do some research on filters and see the difference, a cheap filter leads to bad oil recirculating throughout the engine.
