Ugg!!! New Vibration!!
Old Apr 17, 2016 | 02:52 PM
Simple8's Avatar
Default Ugg!!! New Vibration!!
Now I have a terrible vibration through the steering wheel. I mean my arms and *** feel like I'm getting a massage. Starts at around 30 mph and then seems to smooth out a little around 55 or 60 mph. I have replaced the transaxle, rotors, pads, and had the tires checked for balance. Any one have an idea? Also replaced the rear u-joint and rubber flange in the rear (rotoflex). I am at my wits end!!
Old Apr 17, 2016 | 03:05 PM
jamieb's Avatar
Shot in the dark, have you checked your motor mounts? Got underneath and grabbed and checked steering arms and linkage?
Old Apr 17, 2016 | 04:41 PM
OffroadFrance's Avatar
Check your steering column UJ etc and also the drag and track control ball joints.
The only other possibility I can think of is the Cardan UJ's on the front drive shaft or possibly the rear shaft UJ and rotoflex coupling. Did you assemble the rotoflex coupling and bolts corretly?
Old Apr 17, 2016 | 08:19 PM
dr. mordo's Avatar
The front shaft has been rebuilt?
Do you have the 3 amigos?
Old Apr 17, 2016 | 09:34 PM
BS50MGSXR's Avatar
i had a slight vibrations/humming sound at around those same speeds, replaced the front drive shaft and it went away. the old drive shafts double u joints had lost lots of movement.
Old Apr 18, 2016 | 06:16 AM
batard's Avatar
Front driveshaft would be the first place to look.
Is there any vibration at idle? Does the vibration increase/decrease with engine speed/rpms? I had a vibration recently that turned out to be a misfire that didn't throw codes. Replaced the wires and it went away.
Old Apr 23, 2016 | 09:46 AM
Simple8's Avatar
Thanks for the help. There is no vibration at idle only moving down the road. And the vibration is continuous at those speeds. Have not had a chance to crawl under it yet. Hoping to tomorrow
cheaptoselling3
May 19, 2009 11:08 AM
Prepilot_3ck
Sep 26, 2006 07:48 PM
