Ultra Gauge Users - Open Loop??
Old Aug 8, 2013 | 02:22 PM
Bryan H's Avatar
Default Ultra Gauge Users - Open Loop??
I've noticed that when driving 40+ mph, if I quickly let off the throttle, the ultra guage shows an open loop condition until I come to a stop or apply the throttle again. Is this normal?
Old Aug 8, 2013 | 02:55 PM
bballjames's Avatar
Yup. Mine does the same.
Old Aug 8, 2013 | 03:08 PM
Time to borrow some ones real time scanner and verify if this is happening, if it is, you have a problem cause once your engine clear around 120 to 140 degrees, you are in closed loop and should not go back to open loop.
Old Aug 8, 2013 | 04:35 PM
kdscott100's Avatar
oh no, mine does the same thing too. But then again, it happens with my VW Passat, so maybe I have two problems, or maybe the problem is the Ultraguage....
Old Aug 8, 2013 | 05:50 PM
honda50r's Avatar
Mine does it too. I'm just thinking a little excess fuel or something, I'm not worried about it
Old Aug 8, 2013 | 06:35 PM
Red_Liner740's Avatar
It goes into open loop because at that point you are engine breaking and its cut off the injectors hence its ignoring O2 sensors hence why its in open loop
Mine does the same thing but also shows 999 MPG on the instantaneous reading.
Old Aug 8, 2013 | 07:27 PM
SSL9000J's Avatar
Same here, I thought this was normal.
Old Aug 8, 2013 | 07:52 PM
honda50r's Avatar
Speaking of UG, I wish we could get actual MPG on the Ultras with our trucks..
Old Aug 8, 2013 | 07:59 PM
Mine goes to open loop when under wide open throttle, which from what I have read is normal.
Old Aug 8, 2013 | 08:38 PM
G Reeves's Avatar
WIDE OPEN THROTTLE
