Ultra Guage Temps ok?
Not bad around town. What are your hwy temps?
re: The factory thermostat is fully open at 204, so yes those are normal. The auxiliary fan should kick in at 212f
While the above is factual, at this cooler time of year, do you expect your thermostat to be fully open? Then what will it have in July? My belief is that the normal opening temp should be what you see most of the time. I like my D1 running at 180-183, and up to 187 on freeway; with a 180F stat. In August. I don't want to be at 215, etc.
Just because your change to this thermo does not mean you will get down slot in temps you could have blockage forming in radiator and this would contribute to your heating up. You will find out after the change of your thermo.
Good point though.
Haha ya that might be true that your radiator is slightly clogged, until your temps get too hot, it doesn't really matter. Put the new thermo in and enjoy your new running temps which should be below 200 all the time.
