UltraGauge Alternative
I bought an iCarsoft 930 last year from AB. I really like it because it can diagnose and monitor all systems. Recently, I have been looking to buy an UltraGauge, but $80 is not something that I want to spend if I don't have to. Is there a way that I can permanently keep the iCarsoft plugged in so I can monitor the coolant temperature? I have monitored it before with this device, but it will not turn off if I take the key out. My goal is to be able to keep it plugged in on the temperature monitor and have it turn off with the ignition, then return to the same screen when the car is back on. Is this possible?
Thanks.
Thanks.
Personally I love my ultragauge. I went with the "Blue" model so I can monitor via an unused tablet. It works great! Next I just need to write a code that turns my tablet on and off with power. If you decide to switch you won't be disappointed. Sorry I can't help with your question though, good luck!
DiscoCam (03-03-2016)
Thanks.
Thanks.
I should been more clear you can monitor h20 temp. It is nice machine but not made to used as an ultraguage.
DiscoCam (03-06-2016)
The following 2 users liked this post by Alex_M:
DiscoCam (03-06-2016),
Mob a Disco (04-02-2016)
