Ultragauge quick set up
i does monitor both O2 sensors and fuel trim.
http://ultra-gauge.com/ultragauge/su...ugelookup.php:
- Open/Closed Loop Emissions Status
- Percent Engine Load
- Engine coolant temperature (°F)
- Engine coolant temperature (°C)
- Short Term Fuel Trim Bank 1
- Long Term Fuel Trim Bank 1
- Short Term Fuel Trim Bank 2
- Long Term Fuel Trim Bank 2
- RPM
- MPH
- KPH
- Ignition Timing Advance
- Intake Air Temperature (°F)
- Intake Air Temperature (°C)
- Mass Air Flow Sensor output in grams/sec
- Absolute Throttle Position Percentage
- Bank 1 Oxygen Sensor 1 Voltage
- Bank 1 Oxygen Sensor 2 Voltage
- Bank 2 Oxygen Sensor 1 Voltage
- Bank 2 Oxygen Sensor 2 Voltage
- Distance traveled with Check Engine Light on (miles)
- Distance traveled with Check Engine Light on (km)
- Brake Horsepower 1
- Brake Kilowatts 1
- Torque 1 (ft lbs)
- Torque 1 (N.m)
- Brake Horsepower 2
- Brake Kilowatts 2
- Torque 2 (ft lbs)
- Torque 2 (N.m)
- UG Battery voltage
- Mass Air Flow 2, Calibrated/Calculated
- Instantaneous MPG
- Intantaneous Gallons/Hour (GPH)
- Instantaneous KPL
- Intantaneous Liters/Hour
- Instantaneous L/100km
- Distance to Empty(DTE)(miles)
- Distance to Empty(DTE)(km)
- Time to Empty (TTE)
- Fuel Level (gallons)
- Fuel Level (liters)
- Oil Distance(miles)
- Oil Distance(km)
- Service Distance(miles)
- Service Distance(km)
- General Purpose
- Average MPH
- Average MPG
- Average Gallon/Hour (GPH)
- Fuel Used (gallons)
- Run Time
- Distance (miles)
- Average KPL
- Average L/100km
- Average KPH
- Average Liters/Hour
- Fuel Used (liters)
- Distance (km)
- TRIP GAUGES
- Run Time
- Average MPH
- Average MPG
- Fuel Used Gallons
- Average Gallon Per Hour (GPH)
- UltraGauge Internal Temperature (°F)
- Average KPH
- Avergage KPL
- Avergage L/100km
- Liters Used
- Distance (km)
- UltraGauge Internal Temperature (°C)
- SHORT TRIP GAUGES
- Run Time
- Avergage MPG
- Average gallons/hour
- Average MPH
- Distance (miles)
- Average KPH
- Avergage KPL
- Avergage L/100km
- Liters Used
- Distance (km)
- RPM
- MPH
- KPH
- Brake Kilowatts 1
- Torque 1 (ft lbs)
- Torque 1 (N.m)
- Brake Kilowatts 2
- Torque 2 (ft lbs)
- Torque 2 (N.m)
- Instantaneous MPG
- Instantaneous KPL
- Oil Distance(km)
- General Purpose
- Average MPH
- Average MPG
- Run Time
- Distance (miles)
- Average KPL
- Average L/100km
- Average KPH
- Distance (km)
- TRIP GAUGES
- Run Time
- Average MPH
- Average MPG
- Fuel Used Gallons
- Average KPH
- Avergage KPL
- Avergage L/100km
- Liters Used
- Distance (km)
- SHORT TRIP GAUGES
- Run Time
- Avergage MPG
- Average MPH
- Distance (miles)
- Average KPH
- Avergage KPL
- Avergage L/100km
- Liters Used
- Distance (km)
So what should the voltages be for the o2 sensors? And what does the fuel trim get you on a regular basis?
Like most, I just have temp and voltage as the big ones, and then trip and instant economy as well as gallons left and distance to empty. However, I must have mine calibrated way wrong as the economy is usually about 2 mpg off. I have the tank set to be 25.5 gal, but it’s usually 2 gallons off as well.
