Ultragauge quick set up
Old Dec 4, 2018 | 07:24 PM
Motorhead1's Avatar
I like the KISS method....I also have my water temp alarm around 215*
Old Dec 4, 2018 | 07:34 PM
Ben Matheson's Avatar
That's exactly what I want but can't get the other junk off my screen
Old Dec 4, 2018 | 07:49 PM
Motorhead1's Avatar
you have to work your way through the different screen options, I choose 3 gauges. I can't remember the details on how to do it.
Old Dec 4, 2018 | 09:03 PM
CollieRover's Avatar
Originally Posted by JUKE179r
Get the ultragauge blue for a smart phone or tablet. You can customize all the gauges you want to monitor.
Does the blue monitor the O2 sensors or fuel trim?
Old Dec 4, 2018 | 11:15 PM
Sandman614's Avatar
https://youtu.be/I8H-nEWZD3g
Old Dec 5, 2018 | 12:21 AM
JUKE179r's Avatar
i does monitor both O2 sensors and fuel trim.
http://ultra-gauge.com/ultragauge/su...ugelookup.php:
  • Open/Closed Loop Emissions Status
  • Percent Engine Load
  • Engine coolant temperature (°F)
  • Engine coolant temperature (°C)
  • Short Term Fuel Trim Bank 1
  • Long Term Fuel Trim Bank 1
  • Short Term Fuel Trim Bank 2
  • Long Term Fuel Trim Bank 2
  • RPM
  • MPH
  • KPH
  • Ignition Timing Advance
  • Intake Air Temperature (°F)
  • Intake Air Temperature (°C)
  • Mass Air Flow Sensor output in grams/sec
  • Absolute Throttle Position Percentage
  • Bank 1 Oxygen Sensor 1 Voltage
  • Bank 1 Oxygen Sensor 2 Voltage
  • Bank 2 Oxygen Sensor 1 Voltage
  • Bank 2 Oxygen Sensor 2 Voltage
  • Distance traveled with Check Engine Light on (miles)
  • Distance traveled with Check Engine Light on (km)
  • Brake Horsepower 1
  • Brake Kilowatts 1
  • Torque 1 (ft lbs)
  • Torque 1 (N.m)
  • Brake Horsepower 2
  • Brake Kilowatts 2
  • Torque 2 (ft lbs)
  • Torque 2 (N.m)
  • UG Battery voltage
  • Mass Air Flow 2, Calibrated/Calculated
  • Instantaneous MPG
  • Intantaneous Gallons/Hour (GPH)
  • Instantaneous KPL
  • Intantaneous Liters/Hour
  • Instantaneous L/100km
  • Distance to Empty(DTE)(miles)
  • Distance to Empty(DTE)(km)
  • Time to Empty (TTE)
  • Fuel Level (gallons)
  • Fuel Level (liters)
  • Oil Distance(miles)
  • Oil Distance(km)
  • Service Distance(miles)
  • Service Distance(km)
  • General Purpose
  • Average MPH
  • Average MPG
  • Average Gallon/Hour (GPH)
  • Fuel Used (gallons)
  • Run Time
  • Distance (miles)
  • Average KPL
  • Average L/100km
  • Average KPH
  • Average Liters/Hour
  • Fuel Used (liters)
  • Distance (km)
  • TRIP GAUGES
  • Run Time
  • Average MPH
  • Average MPG
  • Fuel Used Gallons
  • Average Gallon Per Hour (GPH)
  • UltraGauge Internal Temperature (°F)
  • Average KPH
  • Avergage KPL
  • Avergage L/100km
  • Liters Used
  • Distance (km)
  • UltraGauge Internal Temperature (°C)
  • SHORT TRIP GAUGES
  • Run Time
  • Avergage MPG
  • Average gallons/hour
  • Average MPH
  • Distance (miles)
  • Average KPH
  • Avergage KPL
  • Avergage L/100km
  • Liters Used
  • Distance (km)
Old Dec 6, 2018 | 12:39 PM
  • RPM
  • MPH
  • KPH
  • Brake Kilowatts 1
  • Torque 1 (ft lbs)
  • Torque 1 (N.m)
  • Brake Kilowatts 2
  • Torque 2 (ft lbs)
  • Torque 2 (N.m)
  • Instantaneous MPG
  • Instantaneous KPL
  • Oil Distance(km)
  • General Purpose
  • Average MPH
  • Average MPG
  • Run Time
  • Distance (miles)
  • Average KPL
  • Average L/100km
  • Average KPH
  • Distance (km)
  • TRIP GAUGES
  • Run Time
  • Average MPH
  • Average MPG
  • Fuel Used Gallons
  • Average KPH
  • Avergage KPL
  • Avergage L/100km
  • Liters Used
  • Distance (km)
  • SHORT TRIP GAUGES
  • Run Time
  • Avergage MPG
  • Average MPH
  • Distance (miles)
  • Average KPH
  • Avergage KPL
  • Avergage L/100km
  • Liters Used
  • Distance (km)
Thank you! I did not know if that was a universal feature or if possibly some makes excluded.
Old Dec 6, 2018 | 02:13 PM
JUKE179r's Avatar
The UltraGauge Blue has more gauge monitors but those where the ones specifically for the Disco 2.
Old Dec 7, 2018 | 09:21 PM
longtallsally's Avatar
So what should the voltages be for the o2 sensors? And what does the fuel trim get you on a regular basis?
Like most, I just have temp and voltage as the big ones, and then trip and instant economy as well as gallons left and distance to empty. However, I must have mine calibrated way wrong as the economy is usually about 2 mpg off. I have the tank set to be 25.5 gal, but it’s usually 2 gallons off as well.
Old Feb 3, 2019 | 06:47 PM
user 739349's Avatar
Banned
Originally Posted by Saturnine
This is how ive got mine setup
I'm interested in getting an UG. I'm wondering if you recommend a model?
