Under carrige cover
Old May 30, 2019 | 07:02 AM
botija69's Avatar
5th Gear
Default Under carrige cover
Good Morning my Discovery Lovers!! can someone help me to how to remove the UNDER CARRIGE COVER/ I can't figure out how to remove it? My disco II has a leak, and don't know where is coming from. Please help
Thank You
Robinson
Old May 30, 2019 | 07:19 AM
CollieRover's Avatar
You detach the front control arm and that creates room. The RAVE manual you can download will show you.
Old May 30, 2019 | 08:26 AM
jastutte's Avatar
Thank You
Robinson
i ended up just cutting my out and not reinstalling.
Old May 31, 2019 | 01:20 AM
Brandon318's Avatar
There's an undercarriage cover??
Old May 31, 2019 | 12:29 PM
Best4x4's Avatar
03-04 have a “drip” tray. You can remove it easily if you jack up the front of the D2 & then slide it out.
Old May 31, 2019 | 12:45 PM
Brandon318's Avatar
Hmm, I kind of want one for my 2002? Would it fit?
Old May 31, 2019 | 01:30 PM
Jeff Blake's Avatar
No you don't. Useless, just makes basic things like changing an oil filter or inspecting the underside that much more annoying
Old May 31, 2019 | 02:12 PM
Red5's Avatar
I have read that running without can affect engine temps. ??? I have it but have never driven the truck without if for comparison.
Old May 31, 2019 | 02:17 PM
escott16's Avatar
I actually enjoy mine. When I change the oil every year it’s nice knowing when I pull it off atleast a couple of 10mm sockets fall out that were once lost
Old May 31, 2019 | 02:25 PM
Friday Night Disco's Avatar
I removed my front cover and left the rear cover in just for some kind of protection from sticks. However, it does a better job of collecting my tools, nuts, and bolts.
