..:: The UNDER DASH FUSE BOX Situation ::..
Old Nov 10, 2021 | 03:56 PM
adolfojbonilla's Avatar
Default ..:: The UNDER DASH FUSE BOX Situation ::..
Hello Roverers!
My 2002 Discovery S2 SE with SAI is needing the under dash fuse box replaced, so if anyone knows somebody selling one, it will be greatly appreciated; we've been looking for one for over two weeks with no luck.
Actual part from truck is YEQ000250, but it has been superseded by YQE000410, so either part number will work.
Truck cranks but no start for over 4 months already, and after many testings, ruling out faults and a few part replacements, we're down to the fuse box as the only thing left to try and fix the issue.
Let me know, thanks! ;-]#
Old Nov 10, 2021 | 05:50 PM
Extinct's Avatar
Did you contact Will TIllerey or Paul Grant or Doc Heydary?
Old Nov 10, 2021 | 06:23 PM
...thanks EXTINCT! ...Tillerey I did .. Paul Grant sounds familiar from Forum, so will look him up, and I'm guessing Heydary would also be here in the Forum, correct?
Old Nov 10, 2021 | 10:24 PM
04disco2va's Avatar
I haven’t used them but Rovers North suggested Goldwing.
Old Nov 11, 2021 | 01:18 AM
Classic2disco's Avatar
Might be able to find a functional one from a salvage yard. I have a local yard with a few discos, all the big stuff is usually stripped but I’ve found abs modulators, wheel speed sensors, SLABS ECU, door motors, fuse boxes, etc from totaled or impounded rovers with otherwise good parts.
Old Nov 11, 2021 | 08:43 AM
...thanks 04DISCO2VA, any more info on "GOLDWING" so I can try and locate them?
Old Nov 11, 2021 | 08:52 AM
...thanks CLASSIC2DISCO; ...true that, there are a couple salvage yards nearby that send me notifications when 2002 Discos or similar enter their yards, and I received one last week, but with the raining going on in my area I haven't been able to go, since Discos usually get parked in flood-prone areas. But I have plans to go this coming Saturday, since it hasn't rain in a week, and area should be dried up by then -fingers crossed! ...I'm thinking this is the best shot I've got, since no look finding the used part online. Thanks again!
Old Nov 11, 2021 | 08:58 AM
logan_gibson's Avatar
I should have a used one on the shelf - or in a parts truck I can pull.
Old Nov 11, 2021 | 09:18 AM
...thanks LOGAN_GIBSON, I'll wait for your confirmation, as well as a couple others that have also reached out. Hopefully one of you guys will be able to pull through. I'll patiently wait, thanks again.
Old Nov 11, 2021 | 10:13 PM
04disco2va's Avatar
Hi Adolfo. Think I found them here. Goldwingrover.com.
Hang in there. I know it’s been a long road for you!
