Unwanted warning lights
Old Aug 20, 2018 | 10:46 AM
woodchip2bert's Avatar
Default Unwanted warning lights
Hoping someone can help (usually can ). My disco 2 has all of a sudden developed a worrying fault with the warning lights on the dash. This can happen daily or can happen after a few days , no consistency, three of the amber lights will come on at the same time namely the anti lock braking system light....the Traction Control light and the Hill Descent control (HDC) failure light all amber lights. These will not go off until the ignition is turned off and then they may not come on again for some days. Once again I would appreciate any help or do I have to result to the LR agents God forbid.
Old Aug 20, 2018 | 10:52 AM
Friday Night Disco's Avatar
Three amigos
plenty of threads on how to diagnose and fix.
do you have a code reader?
Old Aug 20, 2018 | 10:54 AM
Three amigos, thanks for that but no ..no code reader and wouldn't know how to use it if I did
Old Aug 20, 2018 | 11:16 AM
Dave03S's Avatar
Well then you better be ready to learn how to maintain your vehicle, be ready to pay someone to maintain your vehicle, or sell it cheap to someone who does. These are not Toyotas where you just get in and drive forever.
What is your plan?
Old Aug 20, 2018 | 12:22 PM
mln01's Avatar
I normally advocate diagnose, diagnose, diagnose, but if you don't have access to a diagnostic tool that can read ABS codes and don't want to buy one or pay someone to do it for you, there's a good chance the fault is related to the shuttle valve switches mounted inside the ABS modulator.
More specifically, there is a printed circuit buried deep in the modulator that very commonly fails. The bad PC can be bypassed, restoring full ABS operation, by performing something called here Option B (search for Option B). Option B requires just a few dollars worth of supplies and relatively simple tools and skills, including soldering. Option B can seem daunting, but it's actually relatively simple to do.
There's a good chance Option B will cure the Three Amigos in your truck, and if not you've not wasted any significant money and you've preventively addressed a problem that might likely occur eventually anyway.
Old Aug 20, 2018 | 12:59 PM
I am too old in the tooth to start learning about codes etc so it seems that I will have to get someone to sort it for me so thanks for your time and suggestions
Old Aug 20, 2018 | 01:01 PM
Where are you located?
we might be able to recommend a shop
Old Aug 20, 2018 | 01:02 PM
Hi and thanks but I am in Norfolk UK
Old Aug 20, 2018 | 03:20 PM
Richard Gallant's Avatar
Basically you have 3 possible problems
  1. As noted by MLN01 the wiring in the ABS modulator you can research the Option B fix and it will tell you all bout those
  2. A failing modulator - the valves inside do go this is the worst case - very expensive as it often requires a new modulator
  3. A bad wheel sensor or damaged wire - the only way to know is to go to a shop that can read land rover specific codes
There are other outliers but these are the most common, I would expect it is most likely 1 or 3 given the intermittent nature of of the lights. You best bet is to go to a shop that can read the codes and find out exactly what is wrong.
Old Aug 21, 2018 | 04:50 AM
JUKE179r's Avatar
What part of Norfolk are you located? I've got a Land Rover diagnostic code reader and I'm in Suffolk near Thetford. I can stop by and help.
