Unwanted warning lights
Old Aug 22, 2018 | 07:31 AM
  #21
jamestfl's Avatar
Amazing kindness is quite common round here. As is the usual curmudgeonly gripes. Most of all- some damn well knowledgeable folks willing to help. Welcome. Keep at it, you'll get that fixed.
Old Aug 23, 2018 | 04:08 AM
  #22
woodchip2bert's Avatar
Even though I haven't actually rectified the cause of my three amigos , because of the help and offer of even personnel assistance from you guys on here I know the problem and possible way to cure it. As with all the forums I prescribe to for various things such as caravanning , biking and numerous other pastimes , there is always help offered by helpful people and it is gratifying to know that help is always out there. Once again thanks to all you guys and your help is really appreciated.
Colin
Old Sep 13, 2018 | 03:28 AM
  #23
continuing the saga.......can someone tell me if instead of bi-passing the wiring on the old switch , would it do the job better if I purchased a new switch and just changed it over? thanks
Old Sep 13, 2018 | 05:29 AM
  #24
mln01's Avatar
No, that won't help because the fault is most often with a printed circuit to which the shuttle valve switches are attached, not with the switches themselves. If you replace the switches the root of the problem will not have been addressed. Do Option B.
Old Sep 13, 2018 | 05:32 AM
  #25
Great stuff.......thanks once again
Old Sep 13, 2018 | 07:46 AM
  #26
jastutte's Avatar
when i had the 3 amigos issue on both my '04's i replaced the switch and did the Option B fix at the same time. figured since i was in there i might as well do some preventive maintenance. especially, considering the mileage on my trucks.
Old Sep 13, 2018 | 11:37 AM
  #27
mln01's Avatar
The switches should be inspected for brake fluid contamination and tested with a multimeter as described in Josh Salas's Option B write-up. Many do go ahead a replace the switches when doing Option B. I inspected and tested the ones in my truck and they were fine so I reinstalled them. All's still well, 7½ years later. The switch assembly is $44.00 from Lucky8 or £51.59 from Rimmer Bros (£32.00 aftermarket).
Old Sep 21, 2018 | 11:00 AM
  #28
Job now completed and followed option B , all fault codes cleared and now have to wait and see. Thanks to all you guys out there that sorted me out
Old Jan 17, 2019 | 07:27 PM
  #29
mln01's Avatar
Well, woodchip2bert, is your instrument panel still quiet or have the Three Amigos returned?
Old Jan 17, 2019 | 09:49 PM
  #30
No not returned...all seems to be behaving
guth127jam
Aug 7, 2013 08:30 PM
eitydeuce
Aug 8, 2012 02:30 PM
Bob Youll
Nov 3, 2010 07:45 AM
slexum
May 10, 2010 02:20 PM
LR_none
Apr 5, 2010 11:03 AM
