upper intake manifold gasket question
Old Dec 7, 2014 | 08:29 PM
dougn's Avatar
Default upper intake manifold gasket question
I'm changing the upper intake manifold gasket and valve cove gaskets. I have to remove the coolant line/tube from the intake manifold that feeds the heater core (to get it out of the way). what's the easiest way to drain some coolant so it doesn't mess when I remove said tube?
Old Dec 7, 2014 | 08:51 PM
04duxlr's Avatar
Does your truck have SAI? If so, you can pull the temp sensor in the radiator to drain some out, Otherwise, you have to pull the lower radiator hose.
dougn
Mar 28, 2015 11:11 AM
MyRoversNameIsCarl
Nov 8, 2014 03:16 PM
brw1982
Jul 21, 2008 11:42 AM
