Upper and lower ball joint replacement
Old Sep 11, 2019 | 12:05 AM
Carlos Man's Avatar
Default Upper and lower ball joint replacement
I’m prepping my 04 D2 88500 miles for a 2in terra MED lift.
I was looking at the ball joints and considering I got the D2 with 88000 miles on it I’m not sure if they have ever been changed. I can see wear in them so I wanna change them for piece of mind.
I’m sure someone has done it on there own and was wondering if it was a pretty difficult job?
If anyone can give me some advice as to the process, tools, tips...I’d really appreciate it. I’m trying to do all maintenance and resto myself so anything helps.
Some of my biggest questions are....
do i I need to remove the CV shaft
and are the joints hydraulically pressed?
Thank you,
Carlos
Dallas Tx
Old Sep 11, 2019 | 10:43 AM
Dave03S's Avatar
Regarding ball joints, I've always heard "If it ain't broke don't fix it."
There are plenty of YouTube videos on the topic to see what all needs removed.
Old Sep 11, 2019 | 12:29 PM
SundayFunday's Avatar
Agree
Old Sep 11, 2019 | 12:42 PM
NewToTheTwo's Avatar
Mine has over 200k - the rubber boots on the ball joints are gone so I've been considering this too.. Probably about time... lol
Old Sep 11, 2019 | 12:54 PM
Carlos Man's Avatar
Originally Posted by NewToTheTwo
https://www.youtube.com/watch?v=Dma_QzkrLUw
I saw this video, he removes the CV shaft... I wonder if it’s necessary considering you’ll have to deal with differential fluid etc.
Old Sep 11, 2019 | 02:01 PM
With your types of questions, I would consider inquiring a shop’s cost to do it for you.
If you take a stab at it, I would Make sure you have a suitable press & cups. And Take good care to ensure the ball joint goes in straight & your press is using the same side arm as it’s pressure applied.
(Meaning don’t use the bottom of the knuckle to apply pressure to the top joint when pressing in/out)
Just takes patience, brute strength, and a basic understanding
jrm123180
Mar 8, 2020 12:33 PM
twr7cx
Dec 21, 2018 04:17 PM
Aj6543
May 9, 2018 02:47 PM
JettsRover
Nov 2, 2017 01:59 PM
marizcal
Mar 24, 2014 03:32 PM
