Upper Radiator Hose - tired of changing
Old Jan 24, 2017 | 09:11 PM
DailyDrivenTJ's Avatar
Originally Posted by sayeedA
I have been reading about that too. is there any benefit doing so? you can get the upper assembly for less than $30 bucks
do you have the instruction and parts needed for it?
http://www.landroversonly.com/forums/f40/inline-thermostat-modification-done-42605/#/topics/42605?page=4&_k=fd3nek
Post #33 has all you need. I have done this a few weeks back and I wish I had done this 16 years ago.
Hasn't seen over 188 yet.
Old Jan 24, 2017 | 10:01 PM
sayeedA's Avatar
I am sorry. I still don't see a big value going through all the mods and shell out almost $150 bucks
Old Jan 24, 2017 | 11:24 PM
T-rex's Avatar
A copper T-fitting has worked really well for me. I have a thick rubber washer on the bolt head on the inside. I did thread the copper hole for what it was worth. Notched the end of the bolt so I could keep it from rotating when tightening the butterfly nut. Flared the ends out so the hose wouldn't be able to pop off under pressure.
Old Jan 25, 2017 | 12:05 AM
sayeedA's Avatar
I see this is the most cost effective way. where did you get the copper T ? size and part number?
I am also impressed by this design someone did but not sure what they used for 3 extensions.
Old Jan 25, 2017 | 12:07 AM
sayeedA's Avatar
did they use this and cut off the Thread at the pipe end?
Attached Thumbnails Upper Radiator Hose - tired of changing-78460986-37fe-44a7-85a8-6faaab7f30a6_1000.jpg
Old Jan 25, 2017 | 11:20 AM
T-rex's Avatar
Standard copper T from Home Depot. I just took the old plastic part with me to match size. Wandered around till I found all the parts I needed. The hardest thing was flaring the ends of the T. I think I used a socket that was a little bigger and a rubber mallet.
Old Jan 25, 2017 | 09:56 PM
LR03NJ's Avatar
Actually while at Home Depot, I went to the tools section and grab a ball peen hammer and insert it on the end and hammer it while youre there. Thats what I did and all the ends got the flaring.
You can also get the brass needle valve LFA-41 drill and tap it on the top of the Tee. Then solder.
Old Jan 26, 2017 | 05:36 AM
OffroadFrance's Avatar
There are custom stainless steel T pieces available with a S/S bleed screw which are online either in the UK or europe. Personally I don't like using galvanised or iron pipe fittings over other materials but that is just me being subjectively picky.
DonRW2007
Jul 2, 2015 12:16 PM
Selvol
Nov 12, 2012 05:18 AM
