Upper Vacuum Leaks - Points of Failure
Old Jul 12, 2024 | 07:35 AM
MAF Diver's Avatar
Originally Posted by MrHSE7
Just following up with where I am with all of these codes.
After extensive searching for a upper air leak to no avail I came back to the forums and was doing more research. I read a post where someone said to disconnect my mass air flow sensor and see what happens. As soon as I removed the MAF connector the car immediately ran better and was no longer stumbling at idle. I cleared the codes and drove it for sometime and all seems well. No more P0174 and P0171 codes. After a restart I did get MAF related codes from it being unplugged. Im guessing that my 2 year old (BOSCH) MAF is failing. Ive already tried to clean it with no results. Ill have to buy a new one I guess or try and see how to test the current one.
In the mean time will I be OK to drive the car with the MAF disconnected? Will I do permanent damage? Seems to be running better than it has in a long time.
Did you end up solving this?
cybercop
Jul 17, 2019 05:42 PM
KingKoopa
Feb 25, 2017 05:03 PM
Charlie_V
Jan 29, 2015 10:29 AM
lrsmith62
Aug 10, 2014 08:31 PM
lmcgrew79
Oct 27, 2013 12:26 AM
