Urgent - overheated on side of road
that'll do for a flush. but- after that, flush with 2-3 gals of distilled water. just plug a funnel in there and let 'er rip. after that, close the hoses back up and do the fill from the overflow bottle with the plastic T-housing screw removed and overflow elevated. lots of write-ups here on the exact procedure. bottle raised. and burp it. may take several times before all the air is expelled. keep at it.
meh, too much trouble with the drain plugs. IMHO, go with 2-3 gal's of distilled water into the top most hoses (the thru-the-firewall ones) and yeah, why not undo the lower hose for a drain. only thing I would add on the bleed procedure- keep an eye on the fluid level in the overflow bottle and keep an eye on the engine temps as you do it. repeat as necessary. oh! and check that all fittings are tight b/f starting- they inevitable get a little loose over time with the expanding and contracting of the hoses. mine are all 8mm/philips head.
Engine temps should be irrelevant in the bleed procedure.
I'm pretty sure it should be bled with a stone cold engine. Once you think you've got it, then turn it on and run for a while, if you still have gurgling under the dash wait till it is stone cold again... even if its the next morning... and repeat.
