Urgent - overheated on side of road
Old Jul 23, 2014 | 02:35 PM
jamestfl's Avatar
that'll do for a flush. but- after that, flush with 2-3 gals of distilled water. just plug a funnel in there and let 'er rip. after that, close the hoses back up and do the fill from the overflow bottle with the plastic T-housing screw removed and overflow elevated. lots of write-ups here on the exact procedure. bottle raised. and burp it. may take several times before all the air is expelled. keep at it.
Old Jul 23, 2014 | 05:03 PM
ge234's Avatar
Thanx James, I was actually looking for those procedures but had trouble finding them.
So I have to dismount the overflow tank, then raise it up? Whys that?
Old Jul 23, 2014 | 05:17 PM
ge234's Avatar
Also, forgot to ask: I found a replacement thermostat (just the thermo, not the plastic casing) for about $10, 180 or 195 degrees. Should I replace the thermo too?
Old Jul 23, 2014 | 07:21 PM
ge234's Avatar
Jared this is a huge help, thanks for taking he time to walk me through it. As a newbie who is tackling these jobs as they pop up, I have to say I wouldn't be able to do this without you guys. The forum literally saved my a$$ when I overhêated.
Thanks everyone.
Old Jul 24, 2014 | 06:00 AM
drowssap's Avatar
do not try and use the block drains
Old Jul 24, 2014 | 08:33 AM
drowssap's Avatar
if i remember correctly the drains are a 3/8"npt plug with the old 4 sided head,
that has been screwed into the water jacket for better than 10-years.
if you can get them out more power to you.
Old Jul 24, 2014 | 09:01 AM
jamestfl's Avatar
meh, too much trouble with the drain plugs. IMHO, go with 2-3 gal's of distilled water into the top most hoses (the thru-the-firewall ones) and yeah, why not undo the lower hose for a drain. only thing I would add on the bleed procedure- keep an eye on the fluid level in the overflow bottle and keep an eye on the engine temps as you do it. repeat as necessary. oh! and check that all fittings are tight b/f starting- they inevitable get a little loose over time with the expanding and contracting of the hoses. mine are all 8mm/philips head.
Old Jul 24, 2014 | 09:41 AM
Dave03S's Avatar
Engine temps should be irrelevant in the bleed procedure.
I'm pretty sure it should be bled with a stone cold engine. Once you think you've got it, then turn it on and run for a while, if you still have gurgling under the dash wait till it is stone cold again... even if its the next morning... and repeat.
Old Jul 25, 2014 | 08:34 AM
jamestfl's Avatar
yeah Dave, thanks for the clarification. stone cold engine first thing in the morning is best. the watching the temp gauge I was talking about is once he starts filling and running the engine. if there's bad/low/no circulation keeping an eye on the temp gauge will be critical.
allen
Sep 11, 2012 09:34 PM
Torancis_LR
Jul 10, 2009 11:27 PM
dlkk
Aug 3, 2007 09:12 AM
unco
Dec 2, 2006 06:32 AM
BMWLR
May 12, 2006 01:44 AM
