Use main bearing caps matched with block or crank?
Old Aug 3, 2024 | 02:37 PM
evil_goat's Avatar
Default Use main bearing caps matched with block or crank?
My new engine block that I am putting the crank in from the old engine came with its crank bearing caps. Do I use the ones that match with the crank or the block. I think it makes the most sense to use the ones matched with the new block since they were likely included there for a reason.
Old Aug 3, 2024 | 04:35 PM
H20nSnow's Avatar
The caps with the block are the correct ones to use. You would expect to have to line bore the block/caps if you used other caps.
robert.juric
Dec 5, 2019 07:05 AM
slammin_LWB
Nov 23, 2016 11:31 AM
1999rover
Feb 17, 2014 01:41 PM
BCDisco2Lando
Jan 9, 2014 06:56 AM
GROVERDISCO
Dec 22, 2012 06:44 PM
