Used engine...
Just bought a 2002 Range Rover 4.6 L w/secondary air engine that I'm going to drop in my 2004 Disco. The used motor has 33,000 miles on it and came with a 6 month warranty. My question is I pulled 1 of the valve covers and it seemed pretty dirty. Could a motor with 33,000 miles and maybe didn't get the proper oil chages look like this. And should it concern me? And second what all gaskets should I replace while I have it on the stand before I drop it in? Thanks for any and all responses. Chris
If the oil was not changed when it should be and they used regular grade gas instead of premium I suppose a 33k engine could be sludged like a 60k engine.
Why does the donor only have 33k?
Was it totalled back in '05 or '06?
If so why did it sit for 4 years without being parted out already?
I know you already bought the engine but you may have been screwed.
I would replace the head gaskets, oil pan, front and rear mains..
Clean the oil pick up screen and clean out as much sludge as you can.
And how would the guy that you bought it from even know if you did change the head gaskets?
Its a lot easier/cheaper to have it done with the engine OUT of the truck.
if this was truly a lo mileage engine then is a safe bet the HG have never been changed and they will fail in the future so swapping them out should be done.
It might be a wise idea to talk with the engine supplier to discuss this idea prior to doing it so to see if a warranty will still be in effect if you do swap out the HGs
