Anything Else To Do to New (Used) Engine
Old May 18, 2009 | 03:36 PM
Bryan H's Avatar
Default Anything Else To Do to New (Used) Engine
Ok, a little background. I have an '03 with a fairly loud engine knock. No idea what caused it, but it's there. I'm not in the VIN range of oil pump failures, and I have installed an oil pressure gauge and have good pressure at all times. In the meantime, I found an '04 that was being parted out. I picked up the engine with about 80k miles on it. I'm getting ready to swap it over into my Disco. I've ordered new magnecors and have Bosch +4's ready to go. Is there anything else I should do to the new (used) engine before I drop it into the truck?
Bryan
Old May 18, 2009 | 03:43 PM
jycsalas's Avatar
make sure it doesnt need ANY gaskets. since you have the engine out it will be A LOT easier to work on it so this will be the BEST time to change head gaskets and anything else that will be difficult to replace once installed.
others will chime in and give their 2 cents
Old May 18, 2009 | 04:50 PM
okdiscoguy's Avatar
drop the pan and inspect. Clean out any sludge and the oil pickup if dirty.
Old May 18, 2009 | 05:35 PM
New front and rear seals, front tranny seal, t/stat and any other gaskets.
I would install the engine and do a full ATF flush to clean out any old build up.
Jupiter Rover's Avatar
Bryan
Hold on there!
No need to swap the engine. It is not like Every 2003 engine in the Vin range fails!! Just a small number.
Your 03 engine might not even fail, it probably won't. Just wait till it fails. No need wasting a good engine.
Old May 18, 2009 | 06:35 PM
Good point but why wait, tear it down now and see if it is repairable before it blows.
Old May 18, 2009 | 06:37 PM
See if the 04 is reparable? I would definitely fix up the 04 just to have it ready. 80K miles isn't bad. I just wouldn't swap it right away. Unless you can swap engines easily and cheaply.
Old May 18, 2009 | 06:38 PM
okdiscoguy's Avatar
Yeah, I was gonna say I will take your old engine.... Even if it is a bearing, they aren't too hard to swap, even with the engine in the truck. For sure cheaper and less work than swapping.
bcolins
Jul 13, 2013 08:43 AM
srockrae
Jan 18, 2013 10:54 PM
XxRoverAllOverxX
Oct 4, 2010 02:47 PM
oysterhead
Apr 10, 2010 08:06 AM
steq184
Freelander
May 14, 2008 03:54 PM
