Using the "add to any color" antifreeze
Old Jan 14, 2013 | 08:45 AM
Bleed some more. On a D2 the coolant is always circulating in the heater core, if you have enough coolant to begin with.
Old Jan 14, 2013 | 09:00 AM
AdrenalinPlease's Avatar
Which bleed? RAVE bleed? 1,500RPM open tank bleed? Both?
When I come out of work today the truck should be stone cold.
BTW whats up with the RAVE? I cant open it.
Old Jan 14, 2013 | 09:18 AM
drowssap's Avatar
there is no such thing as a "1500rpm bleed".
Bleed it when it is cold, raise the recovery bottle, (not so high as to kink the bottom hose.)
Pull out the screw and fill the raised recovery tank.
Leave the screw out for little while do not close it as soon as coolant comes out, let the coolant run for a minute, then close the screw.
top off the coolant recovery tank the next couple of mornings when cold and you should be alright.
Old Jan 14, 2013 | 09:33 AM
My new belt
Im not drawing blood again changing the belt back to the crappy one, Ill use some rags I guess thanks!
Old Jan 14, 2013 | 09:34 AM
For the RAVE, two links in my signature, one has the major files already broken up into pdf and you can download what you want for your truck.
and X2 on bleed for more than the first squirt. All the bubbles may not be right together in one spot.
Old Jan 14, 2013 | 09:38 AM
Makes sence as I have never done it this way, I thought quick open and close lol
Yea it says the file is corrupt.
Old Jan 14, 2013 | 09:54 AM
I just downloaded the D2 shop manual (about 35 mb) from the second link and it works fine, over 1500 pages of pdf fun.
Old Jan 14, 2013 | 10:34 AM
Hmm ok that works, the first link though doesnt. Not the link but the D2 manual file
jycsalas
May 23, 2019 03:02 PM
Malcohmh
Sep 18, 2014 08:20 PM
suzukisam967m
Oct 26, 2013 04:31 PM
Mtree
Jun 19, 2009 08:46 AM
mag48
May 18, 2009 09:52 PM
