Using break cleaner
Old Mar 21, 2008 | 09:03 PM
starcraft's Avatar
Default Using break cleaner
I am going to be replacing my brake pads tomorrow and I got a can of brakleen brake cleaner to spray everything down. What I wanted to know is if this stuff is safe to use on the abs sensors. I dont want to go spraying around everything and possibly mess something up. Thanks for the help
Old Mar 21, 2008 | 09:14 PM
Default RE: Using break cleaner
Do your self a favor, only using this after you have installed your new pads and bled the brakes. Only you it on surfaces where you have spilled brake fluid.
Make sure to have a least 1 quart of brake fluid to flush the brakes when you are done, and use sound deadening spray to keep the squeaks down.
Old Mar 22, 2008 | 11:33 AM
schultze5100's Avatar
Quick question is there some sort of step by step instructions on how to bleed the brakes, and what are the benefits for doing it?
Old Mar 22, 2008 | 12:32 PM
Mark G's Avatar
The benefits of bleeding is to:
1) Replce brake fluid and purge out any moisture that may have gotten into the system (Brake fluid is hygroscopic, meaning it attracts moisture). A normal course of service work, and good preventative maintenance includes periodically replacing the brake fluid about every 30k mi.
2) Purge out any air that may have gotten into the brake system, or more likely, wasn't completely bled out from previous service work. Air is compressable, fluid is not. Therefore it could firm up your pedal and improve braking if there was any air in the system.
Make sure when you bleed your brakes, you keep checking the resivour and add fluid before it runs dry.
targotsi
Jan 31, 2009 06:12 PM
DeepBlueWater
Oct 15, 2007 07:38 PM
kcirtap
Oct 12, 2007 08:32 AM
bigugly82
Apr 16, 2007 11:55 PM
jasonsLR
Jul 2, 2005 12:12 AM
