Using a fog machine to diagnose p1171/74 combo?
Old Aug 5, 2015 | 11:56 PM
Freedom38's Avatar
Default Using a fog machine to diagnose p1171/74 combo?
Would a fog machine be safe for sensors and such? Or would it do more bad than good?
Old Aug 6, 2015 | 08:20 AM
First what year is it, how many miles on it and what other codes are showing ?
If you had a major vacuum leak, yes it will find the leak.
Old Aug 6, 2015 | 08:15 PM
Freedom38's Avatar
2003, about 116k, engine has about 60k p1171 p1174 are the only codes and it won't pass emissions so I need to get it fixed
Old Aug 7, 2015 | 02:34 PM
Start by looking to make sure you have no vacuum leak at the manifold and the header connections.
Old Aug 7, 2015 | 04:43 PM
Andy2Rover's Avatar
If you don't find a vacuum leak anywhere, do your fuel injector seals. That solved mine and several other board members and most likely is your issue unless you find a vacuum leak in the intake hoses.
Old Aug 8, 2015 | 11:48 AM
Freedom38's Avatar
If it is the fuel injectors, how do I check to see if they are leaking?
Old Aug 9, 2015 | 08:07 AM
Andy2Rover's Avatar
I didn't do a test. It was a safe bet after I eliminated all the other usual suspects.
me6067
Jul 2, 2015 02:50 PM
aTX427
Feb 20, 2010 09:23 PM
OldDirt
Dec 8, 2008 07:25 AM
04DISCOINHR
Tires
Aug 14, 2008 07:32 PM
Jantiz
Tires
Feb 8, 2007 04:01 PM
