Using a "Signature" Pic
So I finally got around to putting up a Sig Pic, and figured I would take some of the guesswork out of it for any body else that is interested in doing so but hasnt got around to it.
First you will click on User Cp in the Bar above..
Then "Edit Signature"
![Name: Sig1.jpg
Size: 124.4 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/48255d1501388551-using-signature-pic-sig1.jpg)
Then at the bottom of the page you should be able to pick you image from your computer and upload it.
Be advised that:
The maximum size of your custom image is 500 by 100 pixels or 9.8 KB (whichever is smaller).
So you might need to adjust the image you plan on using.
Once you upload the image you should should see it there in the "Edit" page, this does not mean you are done. You need to click the "Insert Sig Picture" text and that will place some [SigPic] text in the text field.
![Name: Sig2.jpg
Size: 140.1 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/48256d1501388551-using-signature-pic-sig2.jpg)
Then simply Grab the image with your cursor while holding left click and drag the image up to the text box.. Position your Curser so that the flashing "|" is beteween the bracketed [SIGPIC]|[SIGPIC] text and then drop it, it should insert a string of text in place of the picture..
![Name: Sig3.jpg
Size: 115.9 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/48257d1501388551-using-signature-pic-sig3.jpg)
Save it and you are done!!
If you want to center the Picture just Highlight all of the text and then click on the Centered text below the "Fonts" bar
![Name: Sig1.jpg
Be advised that:
![Name: Sig2.jpg
![Name: Sig3.jpg
on
Pancho,
I can upload the pic. However the "Insert Signature Picture" text (above the "Delete current image" text) that you have circled in red does not appear. There's nothing to click on to get the [SigPic].
I'm stuck on this step:
"Once you upload the image you should should see it there in the "Edit" page, this does not mean you are done. You need to click the "Insert Sig Picture" text and that will place some [SigPic] text in the text field."
