V288/FV308 PCV Install (Best4x4 Mod)
Old May 14, 2020 | 03:51 PM
  #121
mln01's Avatar
When I did this mod last fall it took some patience to get the baffle out of the tube, as Best4x4 acknowledges. I sprayed it with carb cleaner or PB Blaster and let it soak for a while.
Then I grabbed and wiggled it with needle-nose pliers, sprayed some more, wiggled it some more, sprayed some more, wiggled it some more, sprayed some more, wiggled it some more and it eventually came out. But not without the top part of it first breaking off.
In the case of my truck the baffle wasn't cruddy enough to block air flow, just cruddy enough to need some coaxing to remove. Patience is your friend, I think.
Old May 16, 2020 | 02:52 AM
  #122
CaptainJaneway's Avatar
I don't understand why you need to remove the plug ....
Old May 16, 2020 | 06:35 AM
  #123
mollusc's Avatar
What "plug" are you referring to?
Old May 16, 2020 | 07:38 AM
  #124
JUKE179r's Avatar
I was wondering about the ”plug” comment also.
Old May 16, 2020 | 08:51 AM
  #125
mln01's Avatar
CaptainJaneway is a newbie. Two posts as of right now.
The reference to the "plug" is probably to the baffle in the tube mounted in the valve cover.
Old May 16, 2020 | 12:06 PM
  #126
mollusc's Avatar
I wondered if that was what was meant as well.
Removal of the baffle is essentially the entire point of this mod. The baffle clogs up far too easily.
Old May 16, 2020 | 02:13 PM
  #127
dparham's Avatar
Default Detsils on 03-4
I guess im confused of what is required on the 03-04 discos... is it not easy to remove? And what am i drilling out that is metal and can that fall into valve cover?
Old May 16, 2020 | 05:53 PM
  #128
Richard Gallant's Avatar
@dparham on 03/04's you need to remove the metal tube lots of penetrating oil and very gently twist,one it starts turning apply upward pressure
Old May 16, 2020 | 06:35 PM
  #129
No Doubt's Avatar
Remove the metal tube from the valve cover.
Inside that metal tube is a black plastic baffle that has clogged it up and typically causes oil leaks elsewhere on your Disco.
Remove all black plastic from inside that tube by any means. Since it is not in your valve cover after you removed it, there is no danger of metal or black plastic falling into your valve cover.
You can, optionally, drill out that metal tube to make its inner diameter larger. That is not mandatory.
Once that metal is clean+hollowed out such that it is just an empty tube, you can reinstall it into your valve cover and be done with this mod (prefered way is to also insert a new part PCV308 into your air intake on its back side, too).
The new PCV part prevents air from your intake going into your valve cover.
The hollow metal tube prevents oil leaks from over pressure building up inside your valve cover.
Old May 16, 2020 | 09:22 PM
  #130
dparham's Avatar
ok Richard I think i understand lol. the one thing confusing me is what does the hose to the intake connect too after wards ( on the valve cover side) or am I just puling it off of tis piece as it will be sticking out of the valve cover with its top 1/4 cut off with pipe cutter and the hose will slide down over it and maybe a pipe clamp? then at the intake stick on and thread the PVC valve and good to go? tat seems pretty strait forward, I guess not knowing what is under the hose on the valve cover side is confusing most people
Thanks!
Dennis
