V8 Disc 2 over fueling
What year is your truck? Is your check engine light on? Have you stayed on top of your services, engine air filters?, how many miles or Km does your truck have? Have you checked to see if you have a hanging caliper?
The company that works with Turner Engineering does ECU flashing for
Economy, Power, etc. That being said, that also depends on your vehicle condition. see link below
http://www.tornadosystems.com/produc...8-thor-engine/
no affiliation btw.
5km/L works out to about 11-12 mpg, which is on the low end of normal for highway running. 2km/L is under 5mpg which is atrocious. You have something going on that an ECU flash isn't going to fix.
Try scanning for pending ODB codes to see if any sensors might be malfunctioning.
morning, its a 2001 with what i think is 260000 km, but service books were never kept up to date, i bought around 7 months agao and serviced the vehicle right away, also done the heads gaskets 4 months ago because one bank was leaking, power is also low!
That being said, you still haven't said if the check engine light is on or if you have any codes.
It seams my dash lights are not working, well some of them so I dont know! I am taking it in today to a specialist where they will be checking all the above and see where we come out! I will keep informed once I have an answer, they say the need 3 days>>Thanks
SolbergFanBoi
Mar 5, 2012 07:05 PM
Snafu / Disco Fries
Jun 20, 2011 08:26 AM
DiscoIIBrandon
Apr 21, 2011 10:48 AM
