V8 Engines
Old Aug 17, 2014 | 03:13 PM
OffroadFrance's Avatar
Default V8 Engines
I was thumbing through an old copy of LRM and came across an ad for these guys. It came to mind that many years ago I used to use their dyno facility on my race car engines. Having seen some of their work first hand it's of the highest possible quality. Pricewise, I haven't a clue whether it's cheap or expensive so I must assume reasonable but they seem to reman the V8 Rover engine to overcome most of the common problems mentioned on here. Just a thought for you guys. (mine's a TD5 )
Turner Engineering - Remanufacturer of Land Rover Engines and supplier of Land Rover engine parts
Old Aug 17, 2014 | 04:45 PM
ZGPhoto's Avatar
Turner does good work, all over the board.
Old Aug 17, 2014 | 06:20 PM
toad2's Avatar
I saw on their website they sell the flanged liners seperately. I wonder has anyone installed their own? I have a 4.0 block in my parts truck. How much machining? Would it be cheaper than buying a short block?
Old Aug 17, 2014 | 06:31 PM
It's very easily doable by a machine shop. Once setup at the right angle it's a matter of line boring a shoulder rebate on each bore. The shoulder concentricity can be done either by clocking into each bore with a dial gauge or indexing along the the correct centres of each bore (data available I believe in RAVE). With a sturdy vertical borer or vertical milling machine with a decent boring head this is a simple operation but the difficulty may come when pressing/sweating in the bore liners. Any reman machine shop worth their salt should be able to do this as a 'bread and butter' operation and probably significantly less cost than a new block already prepared. I have never done this but it would be worth enquiring at a reman machine shop for the costs.
Old Aug 18, 2014 | 10:12 AM
drowssap's Avatar
toad2;
installing flanged liner is not a DYI project
aussiejo
Defender
Nov 27, 2006 10:27 PM
karl_page
Dec 27, 2005 05:45 PM
01greendisco
Oct 12, 2005 01:14 AM
nikos
Jun 12, 2005 02:05 AM
nikos
Jun 2, 2005 02:20 AM
