Vacuum Diagram?
Old Jul 11, 2009 | 07:21 PM
TheRepairatorium's Avatar
Default Vacuum Diagram?
Hello, I have a 1995 Disco I 5-speed with the 3.9V8i and I would like to find some pictures or diagram showing the proper vacuum hose configuration. I do not think it has ever been correct. I have the problem of low power and poor mileage. I have already replaced the plugs/wires and both O2 sensors. There are two nipples on the check valve below the distributor cap, but only one hose going to the throttle body. Is that correct?
Thanks,
Brenden
1995 Land Rover Discovery I - 5 Speed - V8i - 146K
1982 Mercedes-Benz 300SD TurboDiesel - 250K
1987 Mercedes-Benz 560SEL - 105K
Old Jul 11, 2009 | 07:42 PM
Sounds like you need to down load a free copy of a Rave CD, then you will have a complete manual to help you thru this.
Old Jul 12, 2009 | 12:27 AM
hazletbassist89's Avatar
Check and make sure first that all your lines are in tact and not leaking. They're prone to a decently high failure rate on rovers.
Old Jul 12, 2009 | 07:52 AM
AK Rover's Avatar
Low power and poor mileage is just typical Rover trait. Only so much you can do about it. Download the RAVE manual by clicking on the link in my signature. That will have all the diagrams you need.
Old Jul 15, 2009 | 05:24 PM
Thanks all, I did download a rave manual and it seems to be fairly complete. I also did a seafoam treatment and that made a world of difference too.
SkyHigh95
Mar 7, 2012 03:46 PM
mj_duell
Oct 19, 2011 03:43 PM
LRadventure
Sep 10, 2010 08:30 AM
saka24
Audio/Visual Electronics
Aug 11, 2005 07:19 PM
ferrelltodd
Jul 24, 2005 01:22 AM
