Vacuum line help
Old Mar 10, 2010 | 05:39 PM
JAGz11's Avatar
4wd High
Default Vacuum line help
I went out to replace my vac lines and most were routed back into each other. Does anyone happen to have a diagram. I've been looking in the manuals but I can't seem to find it.
Old Mar 11, 2010 | 12:32 AM
TBIAgent69's Avatar
Isn't there a diagram under the hood? Sorry I don't have one to give... just a thought. Did you download the rave manual?
Old Mar 11, 2010 | 01:29 AM
JAGz11's Avatar
4wd High
There are parts of them but they are pretty weathered. I downloaded the manual. I looked for a while. I will go back over it just in case I was having an estu problem with the manual.The ones I am having problems with are the ones that go from the brake pedal, the valve cover and to the air box,
Old Mar 11, 2010 | 10:36 PM
TBIAgent69's Avatar
Generally the valve cover will connect to the air box. The brake pedal will go to the largest vacuum source on the intake manifold.
Old Mar 12, 2010 | 09:36 AM
Down load a free Rave CD from the link in my signature section and you will find all you need.
searanch
Nov 22, 2011 05:54 PM
jycsalas
Oct 21, 2008 11:49 AM
cptshanman
Jul 30, 2008 09:19 AM
breal372002
Jun 27, 2007 11:40 AM
dammad
May 8, 2007 12:22 PM
