Vacuum line for seafoam
Old May 5, 2007 | 09:02 PM
dammad's Avatar
Default Vacuum line for seafoam
Does anyone have a picture or description of which vacuum line to use to put seafoam in? I'm thinking of pulling one off the vacuum resevoir, but wanted a confirmation. I've seen several posts from DiscoMike helping folks out, but never a picture or write up. I'd hate to put DiscoMike out again. Perhaps for once, somebody whos done it can post a pic or description.
Cheers.
Old May 5, 2007 | 09:06 PM
Default RE: Vacuum line for seafoam
What year is your Disco, if it id aD2 then send me your e-mail address and I will send you a good photo, if it is a D1 then use the smaller line going to the booster. Biggest trick is to take about 2 minutes to slowly allow the liquid to be sucked into the engine.
Mike
mikeljacobs@comcasy.net
Old May 6, 2007 | 09:03 PM
dammad's Avatar
I did the seafoam (thanks to Mike for the pics).
After the vacuum line part of the process and shutting off the engine, I did get some smoke on restart (particularly when I revved the engine) but not the huge amounts I was expecting. More like a continuous puff of white smoke.
Perhaps my expectations were too high on the smoke.
Engine runs a little better at the mid-rev range, but stumbles a bit at the 1-2 RPM range in my opinion. I noticed that the little red ring on the intake manifold (where the vaccum attached) looks to be broken (partial ring). Perhaps there's a vacuum leak somewhere?
Old May 8, 2007 | 01:31 AM
NevadaXJ's Avatar
4th Gear
ORIGINAL: dammad
I did the Seafoam on my Jeep Cherokee a few months back, and got so much smoke that I couldn't see my house. I was waiting for the fire dept to show up.
I was considering doing this to my 03 Discovery, as acceleration seems lacking.
Old May 8, 2007 | 01:56 AM
Brad S1's Avatar
I was told never to use seafoam on d1s because on higher mileage motors it could damage seals... Any truth to this?
Old May 8, 2007 | 11:11 AM
ORIGINAL: dammad
Did you put one can of SeaFoam in the gas tank and one can thru the intake manifold?
Yes you have a leak and that parts needs to be replace.
Mike
Old May 8, 2007 | 11:12 AM
ORIGINAL: Brad S1
I ran SeaFoam trhu my lawn mower once, it won't hurt any engines or there seals, somebody was just misinformed.
Mike
Old May 8, 2007 | 12:22 PM
Brad S1's Avatar
Thanks Mike!
kfx4001442
Apr 29, 2009 10:58 AM
jycsalas
Oct 21, 2008 11:49 AM
cptshanman
Jul 30, 2008 09:19 AM
Phototone
Apr 8, 2008 03:41 PM
breal372002
Jun 27, 2007 11:40 AM
