Vacuum pump?
Old Feb 11, 2016 | 09:18 AM
clint70's Avatar
Default Vacuum pump?
I'm looking for information on vacuum pump and lines for an 02 discovery 2 non SAI. My brakes are tough and cruise control does not hold... Looked in Rave but not seeing anything. Pls help.
Old Feb 11, 2016 | 09:22 AM
drowssap's Avatar
i do not believe a d2 uses a vacuum pump like RR, i believe you get your vacuum from the manifold.
iirc it is the line with the red collar on it going into the passenger side of the upper intake.
the rubber hose to the cruise control are always roughten and cracked from engine heat
Old Feb 11, 2016 | 10:53 AM
mollusc's Avatar
The cruise control unit has its own little vacuum pump, mounted on the sidewall of the engine bay (on my '99 at least). It's not connected to the braking system (other than the cancel valve) or to the manifold.
I'd suspect leaks in the cruise control lines, as drowssap suggests.
Old Feb 11, 2016 | 11:37 AM
number9's Avatar
Thanks, learned something else new today. On D2 also per manual.
File Type: pdf
Danobp
Jun 3, 2014 04:15 AM
commander3260
Aug 29, 2011 08:33 PM
paris1099
Sep 26, 2010 01:47 PM
anonimaus
Sep 5, 2006 08:37 PM
baobab
Feb 11, 2005 02:45 AM
