Sponsored by: CARiD
vacuum reservoir 2004 discovery
Old Nov 28, 2013 | 11:22 AM
rgemmett's Avatar
4th Gear
Default vacuum reservoir 2004 discovery
What does it mean to have oil in my 2004 Discovery vacuum reservoir filter? Do I just replace it or is the problem elsewhere?
Old Nov 28, 2013 | 03:25 PM
Where is the oil? Do you mean the coolant reserve jug? That would be head gasket.
Old Nov 28, 2013 | 04:04 PM
rgemmett's Avatar
4th Gear
This is part of the SAI system on top of the engine on the left-hand side,a black cylinder with a vacuum tube at each end.
Old Nov 29, 2013 | 08:07 AM
dougwrench55's Avatar
I suggest you remove the intake tube and inspect the throttle body bore. If there is significant oil in there as well there is a good chance the oil seperator (I.E. PCV valve) is clogged. This creates pressure in the crankcase and pushes oil up through the breather tube into the intake manifold.
Old Nov 30, 2013 | 06:36 PM
rgemmett's Avatar
4th Gear
Default Vacuum Reservoir
Thanks for the suggestion. I will try it out.
dgilaon4
Jul 28, 2009 08:59 PM
dgilaon4
Jul 17, 2009 12:52 PM
