Vacuum test
Misfires on the entire left bank. Just read fresh codes in order p1300 p0303 p0305 p0307 and pending p1668. Motors runs but stalls out after about a minute of idle. I can keep it on by reviing her up though. I'm thinking a clogged catalytic converter and I will be running full tests including cylinder compression test, vacuum leak test, and exhaust back pressure test. Any thoughts mike?
You can use the vac line from the passenger side valve cover to the intake plenum. This will disable the "old style PCV" system during the test, but should not make a code. BTW, while there, might want to clean out that oil separator spiral plastic thingy that pokes down inside the valve cover. IACV need cleaning?
