Sponsored by: CARiD
02 d2 block vacuum test ???'s
Old Nov 13, 2014 | 11:22 AM
badassbmwm3's Avatar
Default 02 d2 block vacuum test ???'s
I have both heads off already as there were combustion gassed getting into the coolant system causing the truck to blow out the new expansion tank cap and eventually overheat. How do I check to make sure the block and cylinder sleeves and all are good in my garage at my house? Any DIY-ers out there with tips before I get the heads to the machine shop and start putting everything back together?
Old Nov 13, 2014 | 01:28 PM
acamato's Avatar
Pressure test the block. There are many threads that discuss it.
Old Nov 13, 2014 | 03:14 PM
I've been looking for such a thread with no avail. I've seen a fee people mention kits you can rent, but have not found anything to back that up either. Can you point me in the correct direction with a link or anything?
That would be greatly appreciated.
Old Nov 13, 2014 | 09:30 PM
acamato's Avatar
A quick Google search "pressure test discovery block"
https://landroverforums.com/forum/di...ailable-39423/
It also listed a few YouTube videos
Old Nov 14, 2014 | 07:53 AM
drowssap's Avatar
if you have not pulled the heads use a regular pressure test loaned by most ap stores
Old Nov 17, 2014 | 06:39 PM
I have and used a regular pressure checker on the coolant system before the heads were removed and it failed. That does not tell you if it is just a head gasket or the block though. Heads are off now and I want to check the block.
Old Nov 18, 2014 | 06:57 AM
drowssap's Avatar
i think "abran" bought one to rent out
Old Nov 18, 2014 | 08:16 PM
abran's Avatar
Ah Ha! I have one. Received it and the water pump that they welded up to hold pressure got warped and would not seal up. I just got it back from the machine shop(after straightening), ready to go.
I have another member who is going to confirm tonight if he needs it, if not I can rent it to you. $50 and you pay for the shipping both ways.
Old Nov 19, 2014 | 06:28 AM
Default That was me
I believe I am the other guy that was talking to you lol. I'm ready to move forward with it. What's your PayPal email?
Sending you and email also.
humroot
Jul 22, 2019 06:33 PM
Jared9220
Jan 7, 2016 06:30 PM
Ad!
Jan 11, 2012 05:57 PM
willlane
Oct 30, 2007 06:13 AM
