valve cover gasket
Old Nov 28, 2008 | 09:48 PM
wesley64's Avatar
Default valve cover gasket
just a quick question.could someone tell me the size of the 12 point socket for the valve cover bolts?i would like to pick one up tonight.
thanks
brett 2004 discovery se7
Old Nov 28, 2008 | 10:11 PM
jkid's Avatar
Default RE: valve cover gasket
8mm. The inside bolts are a bit ofa tight fit, so get a 1/4' socket if you can, but a 3/8' socket will do.
Old Nov 29, 2008 | 09:23 AM
Factory torque specs were only 6 ft/pounds, so tighten them to around 12 so they won't vibrate loose.
Old Nov 29, 2008 | 09:58 AM
igriego's Avatar
My valve cover gaskets are leaking how hard is it to change has anybody done this before. thank you for your inputs.
Old Nov 29, 2008 | 10:17 AM
Don't change them, tighten the bolts on the v/c's even if you can only do the 2 outside bolts, then power scrub your engine so it is nice and clean. You should find tighten them snug, not over tightened and the leaking should stop.
To replace them require you yo remove the intake manifold.
Old Nov 29, 2008 | 10:51 AM
jkid's Avatar
ORIGINAL: Disco Mike
I put a dap a blue locktite on my inside bolts since they're so hard to get to.
Old Nov 29, 2008 | 05:53 PM
I just tightened mine, only the two outside ones, leaking stopped. Just snugged with a 3/8" socket and a 6" extenstion.
yarddawg
Sep 22, 2008 03:15 AM
discomaine21
Jan 6, 2008 10:58 PM
humroot
Nov 4, 2007 12:05 PM
wease206
Mar 1, 2007 07:38 PM
