Valve cover gasket slip?
Old Feb 16, 2016 | 03:09 PM
Atlrover89's Avatar
Default Valve cover gasket slip?
About to have a head gasket job done and as I was looking things over I noticed this:
If I'm not mistaken its the valve cover gasket, but as far as I know I'm not having any symptoms. It is possible that when I overheated the engine recently (hot but no light/shutdown) this could have caused the slip?
Old Feb 16, 2016 | 03:25 PM
mln01's Avatar
Looks like your headgaskets may have been done once before at least. And the valve cover gasket looks like either sloppy installation or over-torqued valve cover bolts that may have pushed it out. In any case if there are no localized oil leaks I wouldn't be concerned about it. No harm, no foul. And I doubt that any recent overheating caused it.
Old Feb 16, 2016 | 03:38 PM
Atlrover89's Avatar
Ok that makes sense.
The head gaskets had been done recently and then I hadn't been monitoring temp on a day trip and a day or two later in about 20 degree weather my temp spiked on the dash. I stopped driving it immediately But the next day when I started it there was the dreaded white smoke and a failed combustion test. Sloppy head gasket job too? I'm just hoping its not a bad block at this point.
Old Feb 17, 2016 | 05:44 AM
drowssap's Avatar
someone over tighten the gasket, i bet if you were to remove it that the little torque ring is missing from the gasket.
yarddawg
Sep 22, 2008 03:15 AM
discomaine21
Jan 6, 2008 10:58 PM
humroot
Nov 4, 2007 12:05 PM
wease206
Mar 1, 2007 07:38 PM
