Valve cover Gasket and Water Pump job
No problem. Somebody had a write up on those bolts and used Allen heads. I didn't torque mine on the intake. If it calls for a low torque setting, I just use a 1/4" drive on em n try not to overtightem them. On the front cover topic, it can be done still in the truck. Chubbs just did the front main seal and I am gonna do mine. The hardest is getting the crank pulley off.
I started with small noises in the Pulley! now I am changing the AC bearing, all the Pulleys, belt, VC Gasket and more
I went ahead and got new bolts (Pic). new bolts have 6 points 11mm head fits perfectly i have not mounted yet. It's too darn cold to be in garage today. 29 degree in Austin TX. Those old Bolts are Joke. There so many engineering screw up on this truck. these Covers are too heavy for only 4 skinny bolts. in my opinion there should have been 3 on each side and design should have been easier to access.
By the way I would love to see how you are going to do the front seal. I am just getting started on the leak tracking. I still think most of my leaks are from Synth oil.
Thanks again for your help
Thanks not too clear but I can guess. I have to look into some video or some other instructions. I will look today to see if I have leaks there. There are some definite leaks under. I have to start from the top one at a time. I don't have any drips just wet in several places.
word of advise never try to do Valve cover when outside temperature is cold. I just struggled with. the Gasket is hard and does not fit i had to clean the Parmatex and going to do inside the house 1st part and let it dry overnight may be before i put back.
I started in the Garage. because of the low temp the darn Gasket kept on shrinking on me.
using permatex copper spray gasket. I am going to put on the Valve side let it dry then spray on the other side before I install. I am sick of this stupid leaks.
designed by some idiots.
Also replacing with new 11mm head bolts. If that still leaks then i will have to bring some big gun - LOL
Mounted the covers on my casual dining table and catching up on the Sense 8 on Netflix - nice and warm
outdoor7or24
Dec 22, 2014 09:31 PM
CaptainCulp
Dec 13, 2014 07:23 AM
bcolins
Jun 29, 2013 09:25 PM
Marni
Jun 22, 2013 05:04 PM
