Valve Cover Gaskets and T-case output
Old Jul 6, 2014 | 04:13 PM
Dane!'s Avatar
Default Valve Cover Gaskets and T-case output
I've put off my leaky valve covers for a little too long. What do I need for the full job and what other optional stuff can I replace while I'm down there?
I also discovered vertical play in my tcase front output, I have everything I need already but a replacement nyloc nut for the flange, does anyone know what size? I can't seem to find it on the forums or on any part site, I reused it last time I did it with some locktite, but I wont reuse it twice.
Thanks!
Old Jul 6, 2014 | 07:07 PM
Scout_Beagle's Avatar
I believe this is the correct nut forthe T-case output flange:
Nut - Transfer Case/Rear Suspension (NY120041L Same Fit As Part # NY120041L ) - Land Rover bolts\clamps\brackets\washers from Atlantic British
Old Jul 6, 2014 | 07:46 PM
Dane!'s Avatar
I saw that also, I just wasn't sure. That site has almost no descriptions on their products.
Thanks.
Old Jul 7, 2014 | 07:12 AM
ralphobell's Avatar
The nut is an M20 you can usually get one from Fastenal or any other Nut and Bolt shop.
Old Jul 7, 2014 | 10:15 AM
Jared9220's Avatar
I am going to replace my front drive shaft and was thinking to replacing the flange at the same time. I have a few questions if anyone here may know.
1) do I need the flange holding tool to get the nut off, or will a pry bar work?
2) the flange kit does not come with a new bearing. Do these tend to wear out and should I replace the bearing along with the flange?
RROJ
Mar 26, 2011 02:37 PM
Disco Ed
Feb 2, 2011 04:04 PM
yloDiscoII
Feb 10, 2010 10:03 PM
Alex M.
Sep 30, 2009 12:34 PM
