Valve cover gaskets and what?
Old Dec 13, 2018 | 10:29 AM
Old Bertha's Avatar
Default Valve cover gaskets and what?
Alright so I'm finally getting around to changing my leaky valve cover gaskets, I got the ones off of Atlantic British, is there a better brand or are these fine?
Is there anything else that I should be replacing while I have everything apart? Spark plugs? Gaskets?
Also am I able to refinish the intake manifold and valve covers with high temp paint or is it better to just clean them up.
Thanks guys
Old Dec 13, 2018 | 11:04 AM
Big Jim Swade's Avatar
Since you'll have the upper intake off, be sure to check to lower intake bolts for tightness. They can become loose.
Old Dec 13, 2018 | 12:10 PM
CollieRover's Avatar
Fel-pro and Mahle make molded gaskets that will retain shape and the little ringlets in the boltholes.
The floppy crappie one’s really torqued me off.
Old Dec 13, 2018 | 12:46 PM
Best4x4's Avatar
I’d slap on a FV308 PCV and ditch the OEM plastic nipple on the intake. Since you’ll have the valve covers off you can remove the baffle as well.
Old Dec 13, 2018 | 02:02 PM
robert.juric's Avatar
Yea if you have the upper intake manifold off, now's the time to do any spark plug wire or coil pack replacements if they're needed.
Old Dec 13, 2018 | 03:31 PM
Fast951's Avatar
Watch the AB video with Tech Support guy Doug doing an '02 D2. He goes through all the steps and shows the parts needed according to his valve cover replacement method on a Bosch engine without SAI.
Old Dec 14, 2018 | 09:52 AM
Old Bertha's Avatar
Where is this located and what does it do?
Okay I got checking the lower intake bolts, CollieRover I'll check those out if the ones I have give me too much trouble, and how does one go about inspecting coil packs and plug wires for replacement? I mean they look good and I run pretty smooth.
What about spark plugs? Are these a replace as they fail or should I change those every year or so? I have had the truck for a year and a half and don't know the last time they've been swapped.
Old Dec 14, 2018 | 10:03 AM
zuke's Avatar
I have done that FV308 mod on a 2002, 2003, and 2004 and I never pulled the valve covers. Just a piece of leather and a pair of pliers and wiggle them out.
Old Dec 14, 2018 | 10:08 AM
Best4x4's Avatar
On the upper intake it’s the line that has a black 1/4 thread plastic nipple. It runs to the right valve cover. The OEM plastic nipple can break, and the OEM baffle in the valve cover can clog. Installing the FV308 eliminates two issues at once.
Old Dec 14, 2018 | 10:14 AM
Old Bertha's Avatar
I'll go try and find it now. Just got it ordered! Thanks
acg
Jun 19, 2018 07:59 AM
grasshopperdisco
May 28, 2014 01:44 PM
certguy12
Jan 30, 2013 10:42 AM
stereo
Jun 13, 2009 03:02 PM
04BluDisco
Jan 2, 2009 02:38 PM
