Sponsored by: CARiD
Leaky Valve Cover Gaskets
Old May 28, 2014 | 12:04 PM
grasshopperdisco's Avatar
Default Leaky Valve Cover Gaskets
What other gaskets do I need to replace when taking apart the top of the engine to replace the valve cover gaskets?
Old May 28, 2014 | 12:26 PM
dusty1's Avatar
the only other gasket that you will disturb is the upper manifold. most people don't bother with that one.
Old May 28, 2014 | 12:35 PM
Plenum gasket or intake manifold gasket, or both?
Old May 28, 2014 | 12:37 PM
BTW, this is my first ever LR, formerly a Jeep guy, had it about 2 weeks, just tinkering on it, fixing what shows up that needs fixing, figuring everything out.
Old May 28, 2014 | 12:41 PM
dusty1's Avatar
GASKET INLET UPPER-LOWER P38A RANGE ROVER & DISCOVERY II V-8, RND308, ERR6621 - Rovers North - Classic Land Rover Parts
i was referring to this ^ little guy
Old May 28, 2014 | 12:45 PM
dusty1's Avatar
well, then. it is a good time to swap plugs and wires, while you have the upper intake off, if that is on your agenda. people like to complain about the difficulty, in accessing the coil packs, otherwise. i do not find it to be that bad.
Old May 28, 2014 | 01:32 PM
Yeah, that was one of the ones I was looking at, also called the plenum gasket, thank you sir, i appreciate all the help, considering plugs and wires anyway, might as well do it too.
Old May 28, 2014 | 01:44 PM
dusty1's Avatar
magnacor or kingsborn 8mm are the suggested, for wire.
suggestions are all over the place for plugs. I have run champion cheapoes and now some bosch iridium things......only difference, I have noticed, is the price.
FlyingZebra34
Apr 18, 2014 02:00 PM
RROJ
Mar 26, 2011 02:37 PM
04BluDisco
Jan 2, 2009 02:38 PM
brw1982
Jul 21, 2008 11:42 AM
herblatham
Jun 25, 2008 09:50 AM
