Valve stem seal replacement questions
Old Feb 19, 2020 | 01:53 PM
Stephen Perez's Avatar
Default Valve stem seal replacement questions
Rovers, has anyone replaced the valve stem oil seals on their own? I can’t find in the RAVE how to remove the coils. I just recently realized what these seals were. On another note, anyone know what these rubber gaskets (16) are for that come in the Atlantic British head gasket kit?
How to replace these?
What are these? Have 16 of them.
Old Feb 19, 2020 | 02:02 PM
Llamasayswhat's Avatar
the large rubber seal is for the GEMS motors, the head kit works for both versions, so those are a toss-out item for Bosch 4.0/4.6 engines
For the valve seal, you'll need to pull the head off, compress valve spring with an appropriate tool, remove the valve keepers, the spring top hat, then the spring, and then the valve will come out of the combustion chamber side of the head. The new seal will then install from the top side
Old Feb 19, 2020 | 02:14 PM
alright, sounds like I won’t be replacing those stem seals then haha and good to know I didn’t forget those other seals somewhere on the block rebuild. Thank you!
Old Feb 19, 2020 | 02:24 PM
Sixpack577's Avatar
Valves are actually easy to remove, and a C clamp compressor is under $20
Old Feb 19, 2020 | 02:28 PM
Sixpack577's Avatar
Old Feb 20, 2020 | 04:49 AM
frostythor's Avatar
Hi I have changed stem seals with out taking the head off and takes a lot of patients to do it, first remove the spark plugs to allow the engine to turn easily, then bring the cylinder you want to work on up to TDC, that stops the valve dropping out, (very difficult to get back in but I have done it), Imade up a simple tool to push the valve sting down to remove the collets it bolted on to the head using the bold hole in between the valves , when you push down the valve will sit on the top of the piston, the continue to push until you can remove the collets, remove the spring and remove the seal, now at this point the only thing stopping the valve falling through is the piston, I now bent an old screwdriver 90% or in a nice curve with a bit if trail and error bent it so I could put it down the spark plug hole and lift the valve , now fit the new seal , spring and top and compress the spring, to fit the collets, if you cant just get the collets in the lift the valve from inside the cylinder using the bent screwdriver, tit the collets and release the spring move onto the next, believe me when I say practice make it faster
Old Feb 20, 2020 | 05:19 AM
Alex_M's Avatar
Reinstall can be made pretty easy by hooking shop air into your spark plug hole, simply picking up on the valve stem till the air is holding it in place, then following standard procedures to reinstall the spring and retainer.
Old Feb 20, 2020 | 07:37 AM
frostythor's Avatar
Yes I can see that could work, but when I needed to do it I did not have a compressor , so I use a bent screw driver,,... lets not forget "improvisation is the mother of invention"
Old Feb 20, 2020 | 08:22 AM
mollusc's Avatar
I've heard of people feeding nylon rope into the cylinder, allowing it to coil on top of the piston. That stops the valve from falling in when you are reinstalling the collets.
Old Feb 20, 2020 | 05:08 PM
frostythor's Avatar
OK but lets not forget when the piston is at TDC, there is not a lot of room above it
