Very Funny Noise, Need Help
Old Oct 19, 2007 | 06:40 AM
Adz's Avatar
Adz
Default RE: Very Funny Noise, Need Help
If the transfer box is leaking you should be able to see it easily if you have a quick crawl underneath. The usual suspects are the front output shaft seal, rear output shaft seal or the seal between main box and transfer box. Well worth checking the breather isn't blocked before paying for new seals - blow it through with an air line to clear it - pressurisation of the transfer box when warm can cause your seals to leak, but this won't happen with a clear breather.
Cheers,
foamwizards
Sep 16, 2011 05:28 AM
MikeThomas
May 10, 2011 10:21 AM
LRDalltheway77
Aug 19, 2009 11:21 PM
nynole
Off Topic
Aug 13, 2009 09:27 AM
pureanal
Jul 11, 2006 09:29 PM
